The Spektrum H3050 have a center frequency of 1520µs at 270hz. The KST DS215MG is also 1520µs but at 333hz. Setup N is the pirouette optimization setting. The swash will kickup, and that high side should always be facing the same way no matter where the helicopter is turned. So if the high side is facing YOU, and the helicopter is nose in, if you turn the helicopter side in, the high side of the swash should still be facing YOU. Hope this helps.
