General Spirit Pro Fbl + Spektrum Dx9 Black
Alex Evans
I'm unclear what you mean by this?. When you go to step 8, what pitch angle is the gauge reading. Can it be adjust to 6 degrees using the slider in the software?
in answer to the previous question.. Yes, use the inner ball position on the swash
Hi Smoggie,
I will start by saying that my problem is now gone, all done.
I was all along working on the (wrong) assumption that all the setup in Step-8 MUST be done through the software only. After receiving a new script from yufasa on the Spirit forum, it told me exactly the opposite - that the setup of leveling the swashplate needs to start with mechanical adjustment of the push rods of Ailerone / PItch and only at the end, to make fine tuning with the software.
The same way I then zeroed the blades with the blades control rods, so after that, when I moved to step 8 , there was no problem for me to go the 6°.
You can see my entire story / long article on the spirit forum
Thanks again
