Harford
Following from a previous post about setting up the electronics on my Trex 700E FBL, I have followed Smoggies advice and have the following :
- Spirit Pro
- Hobbywing Platinum HV 130A V4 ESC
- SPM4649T Serial Telemetry Receiver
- JETI integration cable
- Telem UNI cable
- SPM9645 satellite Rx
Are you able to help me please with how I connect this system up correctly.
This is what I understand so far.
SPM4649T is connected from the Serial/Bind port using the Jeti integration cable to the Spirit with the orange wire/plug into the Ele/Pit/Ail port on the Spirit, and the Red/Brown wires/plug into the Rud port on the Spirit.
Hobbywing ESC throttle signal cable connected to Aux 2 on the Spirit (standard powering set up)
Assuming the above is correct, this is where I need help. I am unsure about connections for both the Laps/Volts/RPM port on the SPM4649T and the BEC output cable plus RPM Signal cable on the Hobbywing ESC. I have the CH0 and Aux 2 ports on the Spirit unallocated to this point.
Your help with this would be much appreciated
Michael
- Spirit Pro
- Telem UNI cable
Michael
