Hi all, I'm pleased to say that I managed to get the basic settings done as per the setup wizard. Actually, I went through three times to make sure
. First time I got a warning about my battery being low so changed it over and then went through without too much trouble in about 20mins. Third time was really just a test to practice a bit more and have a look around.
One thing, which isn't explained is why some cyclic geometry settings are negative (mine is -6.0 deg). There's only a message pops up when the cursor passes over the up/down arrows to make the adjustment. Mine was achieved with 230 somethings (there are no units shown only a range up to 250, I forget the lowest value right now).
According to the setup wizard, I'm ready to fly now. I checked out the pitch and needed to shorten the links by 1.0 turn (blade 1) and 1.5 turns (blade 2). Now I've got zero at 50% collective and +10.1/-9.5 (max/min).
I'm going to read up the advanced setup features and put down a summary of my whole experience with the setup process.
What do I like about the experience? There's no pressure to do stuff within a certain time limit that I can tell. It's possible to do it in parts and build up the settings although after some practice it's best to go through completely just to make sure.
What don't I like? When setting up the initial connection to the DSMX receiver the instructions about LED indications were total nonsense. To achieve the binding with my JR ProPo DSX9, I had to exit the software. The same was true for the servo direction changes in the transmitter. There was nothing in the instructions to say that extra windows appear to save the initial Rx setting. Also there's nothing at all describing the setup wizard in the instructions. I took a series of screenshots and will look them through and include some appropriate wording to supplement them. Of course, all for family consumption
Bye for now!
