Hi all, Hugo cancelled due to a short notice business trip
..................... so I returned to the problem myself as he's not back until Wednesday.
First thing was to start from the beginning, so I hooked the gyro up to the laptop and began with the basic setup, oh no! The gyro was still set to the default setting of 'Horizontal zero degrees' and I installed the gyro 'Horizontal 180 degrees'.
The reason for my mistake was that I didn't recheck after following the Goblin manual's tip to set up the servos' neutral setting before installing them. This was a bit of a challenge as it turned out but it was good tip as there's hardly any space to fit/refit the servo arms when the servos are installed. Of course the mounting of the gyro didn't matter with all the bits on the bench but I forgot to go back and check the setting before going ahead with test hovers #1 & 2. As it turned out it wasn't very expensive but of course extremely embarrassing and frustrating. One mistake that I'll never make again.
Having smashed up one set of blades, I didn't want to go ahead and do-in another set so I made up a new set of three using some blades that were in the bottom of one of my spares' boxes. They were from a collection of 325 mm blades I bought when in Singapore (wooden, not carbon fibre). I figured that I only needed them to lift the heli off the deck, hold a stable hover and nothing more. They worked perfectly
I'm still going to see Hugo Wednesday and buy some new blades together with a spare set plus some upgrade bits. I didn't find out until opening up the packages that the Goblin servo arms are an upgrade together with aluminium servo mounts. I didn't like the standard plastic ones at all. I also need another battery mounting tray as I have three batteries. I'll stay with Velcro fixings rather than the double-sided fixing tape provided as standard but each battery will have a dedicated tray.
