Micro Super bad 130x is tost
heli-maniac
Got a Email with what they are sending me
From: Kim Lam [mailto:kim@egrmart.onmicrosoft.com] On Behalf Of kim@xtreme-production.com
Sent: Monday, January 27, 2014 1:47 PM
To: Kee Ho
Subject: FW: Blade 130x tails shaft
Kee
Please send replacement parts:
Jesse Mitchell
Watauga TX.
USA
B130X01 Solid Carbon Main Shaft - BLADE 130X
B130X02-S Titanium Rotor Hub (Silver) Blade 130X
B130X03-S Alu. Main Blade Grip w/ Thrust Bearing (Silver) Blade 130X
B130X06-2 Double Bearing Steel Tail Pitch Slider - BLADE 130X
B130X07-X Tail Shaft (For Xtreme Production Blade Grip B130X14) Blade130X
B130X08 Auto Rotation Gear Set- Blade 130X
B130X10-S Integrated Tail Gear Unit w/ Angular Contacted Bearings (Silver) B130X
B130X11 Carbon Landing Skid Set (Black) - Blade 130X
B130X14-S Alu. Tail Blade Grip w/ Tail Shaft (Silver) Blade 130X
B130X20 DFC Linkage Arm (2 pcs) -Blade 130X (Options for Xtreme Main Rotor System)
B130X22-AB Hardened Steel Bevel Gear (Front Gear A & B) -B130X
B130X22-CD Hardened Steel Bevel Gear (Tail Gear C & D Set) -B130X
B130X26 Carbon Fibre Frame Set -Blade 130X
B130X27-S Alu. Swash Plate V2 w/ Back AR Guide (Silver Blade 130X
Coming from Hong Kong so it will be a few weeks before I see any of it
So Ill finish patching it back together
Got the Lynx Tail grips and shaft Today so it will be flying soon
heli-maniac
Think I found a FBL unit for the build its a clone of a Beast X
Hobbymate V2.0 FBL 3-Axis Gyro
Just got to see if ti will run on just a sat rx like the BX
