Slobberdog
Yeah that is true Westy! But it can be done no matter which servo is plugged into which channel. But yeah it's definitely a good practice to develop of plugging them into the same channel every time so you don't forget!
Yes it does matter which servos are plugged into which channel, what Westy has said is completely right, and yes it is good practice. The only servos that can be inter changed are pitch and aileron, elevator has to be in the correct channel or you will not get it to work, the elevator will always be in line with the boom and can be infront of the shaft or behind,
