Trucks T-Maxx Pro 15
Bearings will never seal 100%. If you are having abnormal idling or lean issues, then look at replacing the front bearing. Otherwise, it's likely fine. All front bearings will leak just a bit. But excessive should be replaced.
Thank you. I do not have a bearing replacement though as it does require a lot of heat to release the bearings. You will need to heat the case up to about 150-200ºF to remove the bearings. Do not try to remove them cold, you will destroy the engine block.
yep I know how to remove the bearings watched your video and already done it once
were you explain how to do it.and the engine block breaks if you thought it was your fault lol
That's why the next RC truck I purchased was an electric one. Nitro is nice but to much headache for me anyway :).
