Well i did some flights tonight, a friend had a temp gun, second pack flight, unless his temp gun is not working properly, temps after second pack was around 170 celcius, after about 5 min brake, then third pack in the air, after flight, was around 190-195 celcius....... What should be an average temp, or was is the around failure temp, i couldn't find much info so far... should i get a brand new Scorpion, is it around burn up time?
Unless i've missread the gun and it was set in F rather then C... because i doubt i would had been able to touch it if it was celcius... i'Ve come to a post that been said,
General rules for brushless motors.
180F and below is good and cool.
181-200F is or but considered hot.
Over 200F and you are headed for a burnout.
Is it right?
