Howdy murankar, Tony and I have pretty much solved the mystery of the bobbing tail. I found a bent feathering shaft. All though I never actually flown it yet, I know that's what was causing the bobbing. Because I have an HK head there's slop all over the place so I wanted to upgrade to an Align head.
Tony, you pretty much read my mind. After thinking about it, your right, find the SE V2 parts or replace and upgrade the entire chopper.
Here's what really concerns me about SE V2 head...
Have a look at the photo below.
The screw that goes through the top of the radius arm NEVER stays in there. As a result I replaced it with a piece of a paper clip. There's play there to but at least it won't come apart in flight, like it almost did once.
Can a nut and bolt and lock tite, be used to correct this weakness?
If anyone knows where I might find the SE V2 head parts, just shoot me the links, thanks...
Ok, time to go shopping...………….
