Hi Steve thanks I may still take you up on the ,I didnt want to loose my trainer switch till after I got Debs flying a CP , working back through the whole day I think the switch had got knocked to on between flying the Trex pro and the Goblin so it was on when I set up the Goblin Now this is where I kick my self , I knew there was a problem I didnt have pitch so I set up again still no pitch ( Now the Doc has changed my drugs and I have been forgetting things and making silly mistakes from the day after ) any way I thought it must be the hold set up playing up so I will flick hold off ,I forgot the motor was powered up still well it spun up and in the few seconds got from floor to 20 feet and a few seconds after 150 feet ( god it fast ) well i knew recovery would make it climb so I hit hold but it would not auto so I managed to aim for some really soft ground , Now I worked out recovery was on so was at max pitch and even after I hit hold recovery was still in so could not get an auto going as pitch was to high , so now the switch is set up so the transmitter will not turn on if recovery is ON , was lucky as all I need is one skid ,one servo arm, If I get NO pitch range again I know its the switch , well we learn by our mistakes just glad it was not worse I temp fixed the skid and fitted new arm test and she flys as before thank god
