grampayeehaa
I finished the 6ft ARF Telemaster build. It has been a lot of fun and an educational venture. All that is needed is a bit of good weather for the test flight. I was very impressed with the kit. I only ran across a couple of small problems that were easily solved. It was predicted that it would only take 8 - 10 hours to complete the build but, because I chose to go with a glow engine, it took a bit longer. If you are a novice builder I would recommend going with the electric motor. The build is a lot easier that way.
