heeheeheeeee ... Whoops!!!
Ill keep an eye on if someone's following me
jk!
Yes you don't need a 8ch anymore bro. Your 6ch (dx6i ..?) will do fine.
Tail servo will probably need to be standard (full size .. 6series) .. It is a 550 size heli. Or else Jesse had a good deal.
If you buy multigov pro... You can tach the heli by a magnet clutch sensor... Or a engine backplate sensor. Engine sensor is a bit more expensive (30 bucks) compared to a magnet clutch sensor which probably will come with the governor.. But installing the backplate sensor is just so so easy as you don't have to open the whole engine and clutch assembly to install a teeny tiny magnet by epoXing it on a drilled hole on the clutch abd then balancing it
And backplate sensor is open two bolts and bolt in on.. Lol
Either way is fine.. Just wanted to make sure you knew your options
Fly safe!!
have fun!
