zenmetsu
You've got a lot straighter RPM curve than I'm getting - I'm going to up my GOV gain a bit I think.
I am also flying with a 1400kV motor that has a lot more power than the stock 1600. I would be willing to bet that your current draw is probably a lot less.
CC has a calculator that will tell you what the max governor setting is, and if you set the throttle on your TX any higher than that, you will not have good regulation of the head speed.
I don't remember what my gain was, I set it to the one recommended for this class of heli, I think it was one click up from the default gain.
