You would look at the manual for your receiver to find out what order it's channels are mapped to what pins on it. The following are the channel assignments for a Spectrum receiver....
Next you'd wire to whatever corresponding pins your gyro state are the channels that the manual for the make/model gyro you have shows. Different brand receivers, gyros etc will each have their own wiring layout so always read everything in each manual. Do not assume that a manual for a certain device is going to know which other brands device you may have... they may show an example layout but that is all they are doing... showing an example so you get the idea.
So if your gyro is a Micro Beast.... don't look at Align's manual which would apply only to Align's own products, look at and read the manual for your make/model.
