GreekRotorHead
In my 450 after a lot of experiment I have ended like that. Throttle curve at 0-75-80-85-90. And a pitch curve of: -9 degrees at low stick/+3 degrees at midstick/ and +10/+11/+12 degrees at fullstick in normal/idle up 1/idle up 2/ modes respectively. I am having also DX9. I am also doing a hover and a little of forward/backward flight. You want at zero throttle to have -9 degrees in combination with enough power at 25% throttle, in case your heli rises up suddenly due to wind and you want instantly to lower it. Also it is good at midstick the heli to begin leaving the ground. On at about +3 degrees. And the landing also with these settings is very smooth and precise. At the moment I am playing with normal mode, +10 degrees at full stick, which is very cool, but if you want the heli become responsive to the smallest amount of move of the throttle stick, then you may use idle up 1 or 2 which at my settings gives as I said +11, +12 degrees at full stick. And in linear pitch curve in hold mode I have -12/0/+12 degrees. Alternatively your throttle settings may be 0-80-85-90-90 or 95 at full stick. You don't have to use all the power of the motor. Its not necessary. But you need a pitch gauge to do all this, preferably a digital one. And one last important thing is when you adjust the -/0/+ degrees in linear pitch curve you don't want the washout base touch the main rotor hub, where the 2 pins are, as it slides up and down the main shaft. You need to be able do a proper set up though.
