Erfan
I tried it almost as you said, but I only took the main and tail blades off, I left the head is it is.
Gave it full throttle and collective pitch back and forth, no issues at all. I gave it slow pitch back and forth, fast back and forth, cyclic (AIL & ELE). No issues...
But as soon as the blades come on its like it has no power at all.
I even checked the rpm with Aligns Multi-function tester (with blades of course) and it as the rpm I expected, around 3000-3200 depending on my idle-up on midstick. So when throttle is either on 80 or 90%.
The blades are btw 360mm blades so the rpm should be good.
I remember once on my t600 I thought the tail had to much play, so I installed couple of shims and no more play. On the bench everything was perfect but as soon as the blades picked up speed the servo could not move them at all.
So the load of the speed forced the tail to get stuck. I wonder if the same is at play here, when the speed picks up and there is force the bad trust bearings jammed the head somehow and the servos are not able to move them.
As with the 600 tail my head moves without any restriction, nothing binds but then its also without any load. Same with that tail, on the bench it was perfect but with full speed and force it could not move. Removed the shims and everything was OK again.
