heli-maniac
thank im going to upgrade the motor wile i have the 550 apart
i have the Align bl 600mx now
here are the specs on the 600mx 1220kv motor
Kv (rpm/V) 1220
Max Power (W) 3000W (5sec)
Max Amp (5sec) 150A
Shaft Diameter 6mm
Motor Diameter 45mm
Motor Length 53mm
Motor Weight 280g
Case Outrunner
ESC Timing 5-18 deg
ESC Switching Freq. 16-22KHz
but i think im going to this the price is right
Scorpion HK-4025-630KV (6mm Shaft) - Scorpion Power System
Kv (rpm/V) 1220
Max Amp (5sec) 150A
Shaft Diameter 6mm
Motor Diameter 45mm
Motor Length 53mm
Motor Weight 280g
Case Outrunner
ESC Timing 5-18 deg
