Surprise, I still have this tank lol. Today is water test and change day and something just happened that has me scratching my head.
Last night, I went ahead and cleaned out the water barrel and made up a fresh batch of saltwater (about 40 gallons). The barrel is right next to the microwave and toaster oven, and I opened one of those shredded beef burrito's and about 3 pieces of the tortilla fell in the 15-20 gallons of water that was in the tank. I should have just done a water change right then, but I waited a week and sure enough, there was a film on the surface of the water in the barrel which was oil and other contaminants. In hindsight, I might should have left it and used that water. You will see why here in a bit lol.
I did clean out the barrel with hot water and a towel (never use soap, I could have used vinegar but didn't) and I put my big AC pump in the barrel to mix the salt because it actually heats the water while it circulates. Welcome to AC pumps and the reason I like DC. I put in 23 cups of salt into the barrel and it came out with a salinity of 1.025, and I need to be at a 1.026, so I added one more cup of salt and it's perfect.
I still have about a degree to go on the temp so I thought I would go ahead and check my parameters. I'm not too worried about Calcium, but may still check it later, so I did Alkalinity, Nitrate and Phosphate.
The Alkalinity was the lowest it has ever been at 5.7dKh. This is NOT good and is the reason the new tank will have a dosing pump on it that will run every evening. So I will be spending the next few days getting this back up to 9.5 where I like it to sit. This just goes to show how much growth is happening in the tank with my hard corals, which is definitely a good thing. But need to get that number up.
The water barrel and the dKh have nothing to do with the reason I started this thread though lol. The reason for this post is the Nitrate and Phosphate
I have been feeding quite heavily and because the skimmer kept overflowing, I have turned the skimmer off and there is no filtration in the tank. I say this to set the image that I have been putting nutrients into the tank via food in which may not all get eaten because I don't turn off the pumps, and with fish waste. But also with no filter socks and the skimmer turned off, there is no nutrient export (nitrate and phosphates).
In checking the nitrates, I tested at a 5.1ppm, which is low'ish, but mostly acceptable. I would like it to be a bit higher, somewhere around 7, but 5.1 is fine. But again, I have no nutrient export and I have not done a water change in 2 weeks.
I then tested the Phosphates, and with my low range test kit that is brand new (just open the new reagents today), I tested Phosphate at 0.00. Now I know why I'm getting black algae on my sandbed. There is an imbalance in nutrients. My corals don't seem to mind (refer to my dKh above lol) and are still growing, so I may have to start dosing Nitrate and Phosphate, which is just crazy to me. I used to battle to keep them low, now I can't keep them at good levels and I don't know why...
I will do another test after the water change and see where we are sitting then, however the nitrate and phosphate will likely remain the same. I'm thinking if I would have left the food in the change water, it may have raised the nitrate and phosphate
