Yesturday evening I had to relock tight the main grips on the X3. They were not in a good place, lucky they didnt pop. Reflowed the solder on the esc to motor wires. Ensured the batteries were being plugged in all the way. Messed with gov store and reset that on the hobbywing 60 amp V4. Went out with 3 packs and got 3.5 minutes in the head started slowing down, had 40% battery left. Hot as hell as normal. Registered 170F on the motor. For what ever reason the Scorpion motor does not like the Hobbywing. Thats my only guess on this. All the mechanics are smooth as silk, tail is almost dead nuts perfect. No reason for high amp draws. My only other option right now is to get another UI sensor and see if it is the amps causing the over heat or if it being caused by the electrons not being used. I have used a 3S on this setup and even it heated stuff up.
I have added a 10T pinion and I am flying at 70% throttle. FOr what ever reason the heli does not like anything over 73%. The tail goes nuts at 75% and up. I tryied dropping the gain and nothing seems to help. Back to drawing boards.
