In this video, I walk you through the DIR setup mode on the gyro. In this mode, you will set all of your blade pitches including cyclic and collective. Please note, you MUST use 8º of cyclic in this step! If you require more than 8º when flying, you will make those adjustments in the Flight Mode Settings in a later video.
Even if you are NOT going to run a Gov, you MUST set the Gov endpoints in the gyro. This tells the gyro where your low and high stick is located. This is a REQUIRED step!
