There are some people that just want to tinker with everything to get it "just right". I happen to be one of those people most times, but with the AR7200BX, I have to say, it's pretty solid right out of the initial setup. But for the rest of those that HAVE to have it perfect, there is the parameter menu on the AR7200BX.
In this video, I walk you through every step of the parameter menu. And if you are running firmware 4.0.14, I also walk you through the governor parameter settings. No worries though, the governor setup video is coming if I can get a new rpm sensor!
Please post any questions, comments or suggestions below.
