Hey K think we're almost ready to go.
Another few points I would like to clarify please, Im running a new (Talk to me Barbie) DX6 with the associate AR610 as i only have the 6 channels to work with.
So:
1. I have Gyro on the TX set to inhibit,,,do I need to set this to something (channel showing on screen is "gear" which is correct according to the way its wired following Tonys video)? If I select flight mode as "switch" ( which would make sense to me) what settings if any should I put into normal..idle up 1 etc I had seen a video where values were listed at around 68,70 percent area.. and the manual lists 70 -80 for TX radio Gyro settings... a confirmation on this info please.
2. Is this where I would make my adjustments if I get a tail wag (tx gyro settings) or will I need to hook it up to the PC and adjust the tail gain section I see in "setting display window"
I getting used to all these settings as in the past eg: trex 150, or the 130x etc I would simply set the radio as per the manual values and off we go... and when I put this one in the air for the first time would like to avoid disaster or nasty surprises...
as always thanks.
