Trucks I play with my T-Maxx
Is it a good idea to Loctite the motor mount bolts that mount the motor to the motor mount I took the motor off of the chassis plate and the motor what screw head backed all the way out and was gone and the other one was backed out still in its spot so I locked item today blue Loctite
Yes, every screw that goes into metal on a nitro should have thread locker on it or it will back out. They have a lot of vibration.
You lower the idle with the idle speed screw on the front of the carb.
As I have stated, you need to lower the idle via the idle adjustment screw. turn it counter clockwise until it stops engaging the clutch in the transmission.
Did you know the T-maxx point 15 head two different Transmissions one was a two-speed transmission and one was a 3-speed transmission what's my local hobby shop and got to talking to the lady that owns it and we talked about T-Maxx .15 and she told me
It could. Just tighten them down and find out. If that was not the cause, adjust the idle screw.
