then my guess would be that they are binding causing them to burn up. Get a volt meter and double check the voltage coming out of the Rx to make sure they are not exceeding 6vDC.
"pump pack"?? Not sure what that is. But I have stated a few times in this thread that they were binding causing them to burn out. Make sure, when you turn the truck on for the first time with the new servos, that you do NOT have the servo horns on the servos!
Just got done testing the voltage of the battery in receiver and all three channels the battery read 6 1/2 volts the receiver channels read six and a half voltage the Traxxas told me that the receiver can handle 6 volts so my question is a half of vote make a difference
Got a new radio system for T-Maxx
Had an issue with a throttle servo no my t Maxx when throttle horn and linkages hooked up throttle servo and we pull the trigger for throttle Servo horn off no sound this normal
