Looks like I am late to the game. As for the charge boards. Go to progressive rc and order up the prc modular balance boards. Then order the lead board that has just wires. Then solder your own connectors.
As for field charging do you need to supply your own port source or do they have power?
I just out fitted my car with a solar rig. It cost as much as a generator but with less maintenance. If you go solar you don't need any extra stuff like power supplies.
If your looking to build a charge case then go to progressive rc again and get the chargery 12v-36v 1500 watt power supply. I have it for when I have access to 110v power. If not I go with my 12v solar system.
My charger is the powerlab PL6 (1000w 40amp @ 36v). The PowerLab PL 8 is 1000w and the pl8 dual is 2688w. Plenty of power .
