If you want a good quality kit and some spares at a good price look at my 450 DFC in the for sale section, see what you think,
Ok I just checked that motor.
It is call the 440, but thats not the KV. The KV is 4200.
So if we know the KV of the motor, the tooth count of the Pinion and Main gear, we can work out the head speed for you.
You are looking for a head speed of around 2500/2700
With the motor and stock 11T pinion on the 140T main gear and a full battery,
your head speed is between 3500 and 4000!!!!
So to get the speed down you can reduce the TH curve to 65 or 60%, but in the long run a smaller pinion will help.
A 10 or even a 9T will be better.
ive just had a look at the blade 450 3d manual and the stock motor is 420 @ 3800kv, the 440 @ 4200kv Lee mentioned is an upgrade for the 450 3d (stock in the 450x). The stock pinion is 10t (there are a 9t and 11t available) and the main gear is 140t
head speeds are working with 90% efficiency :
420 motor 3800*11.1*.9*10 /140=2783rpm
440 motor 4200*11.1*.9*10/140=2997rpm
neither seem to be crazy fast at 100% for a 450, i have seen a 450x flying that has the 440 motor and it did sound crazy fast but that was just the high pitch sound of the motor.
It sounds, to me, that the culprit has been identified....and rightfully so. Sounds very possible and potentially probable.
I bought my 450 Pro from Tony (RCH Owner) as just a frame, head, and blades....no electronic. I made the "rookie" mistake of getting a 3600kv motor from Hobby King. I was using a 12 tooth pinion and the headspeed was just insane and slightly terrifying. I dropped to an 11 tooth pinion and I still only run 80% in Stunt 2. I'm actually wanting to get the 3S Dominator motor. It's a 3200kv motor. I think I'd appreciate the higher torque.
Anyway....Tony, I think you have plenty of "food for thought" from this thread and the guys helping out. I hope your next 450 helicopter goes smoothly for you. Granted, crashes are going to happen, but it sucks when the helicopter just goes crazy and destroys itself. I wish ya luck buddy!!!
