What's up everyone! I FINALLY sat down and fired up the camera and the screen recording software to shoot the Betaflight setup video on the Omnibus F4 Flight Controller. I have installed this FC on FrankenQuad and in this video, I show you everything I did to it to get it ready for a maiden flight. I have already technically done the maiden flight, but we can always do a "remaiden" right? lol.
If you are wanting to setup a flight controller, this video should walk you through all of the steps required to get it in the air. I did not do anything to the PID's in this video, in fact, I didn't even go into the PID menu on this board. First step in setting these up is to get things working, go out and fly it and see if changes need to be made. If you have any kind of oscillations, then you will go into the PID menu and set those up. More on that in another video.
As always, questions, comments or suggestions, post them below! I have included all of the links I mention in the video plus a few more below the video in this post.
Omnibus F4 Flight Controller: Omnibus F4 BetaFlight 3.2.0 OSD STM32F405RGT6 Flight Controller for RC Drone FPV Racing 30.5X30.5MM
Lipo Battery: ACE TATTU 14.8V 1550mAh 75C 4S 1P Lipo Battery XT60 Plug for Skylark M4-FPV250 Mini Shredder 200
Aomway Commander Goggles - Aomway Commander Goggles V1 FPV 2D 3D 40CH 5.8G Support HD Port DVR Headtracker For RC Drone
Flight Controller Beeper - 5 PCS Super Loud 5V Active Alarm Buzzer Beeper Tracker 9*5.5mm for RC MultiRotor FPV Racing Drone
Lisam LS-210 Frame Kit: Lisam LS-210 210mm Carbon Fiber Frame Kit Mini Quadcopter
4x Racerstar Brushless Motor: 4X Racerstar Racing Edition 2205 BR2205 2600KV 2-4S Brushless Motor Purple For 210 X220 250 280 for RC Drone
1xRacerstar Brushless Motor: Racerstar Racing Edition 2205 BR2205 2600KV 2-4S Brushless Motor Purple For 220 250 280 RC Drone FPV Racing
Eachine Stack-X 4 in 1: Eachine Stack-X F4 Flytower F4 FC Built-in VTX OSD 1080P DVR 4 In 1 35A Dshot600 ESC for RC Drone FPV Racing
Stack-X ESC Only: Eachine Stack-X F4 Flytower Spare Part 35A 4 In 1 ESC 2-6S BLHeli_S Dshot600 Ready For RC Drone FPV Racing
RunCam Split 2: RunCam Split 2 FOV 130 Degree 1080P/60fps HD Recording Plus WDR FPV Camera NTSC/PAL Switchable
Video Transmitter: Eachine TS5823L 5.8G 200mw 40CH Raceband Mini FPV Transmitter Skyzone Boscam Upgraded
Aomway Antenna: AOMWAY 5.8G 3dBi RP-SMA Male Four Lobe RHCP VTx/VRx FPV Antenna
Support This Channel - https://www.Patreon.com/RcHelp
