im also getting a lot of beeping in the setup guild it says to move the stick up and it will fix it but it does not for me.. infact the i have no motor turn at all
when my right stick is centered, should the swash plate be flat.
ok so its helping a bit but i cant see the pictures you have posted.
so once i have the arms at 90 then put the links back on and see if its level and if its not then i use the plate to make sure the links need to be shorter or longer?
Correct![]()
ok so i thiink i got the swash figured out. now, i just have a question about the angle of my blades, at 0 throttle, i have 5+ degrees, at mid stick its zero degrees and then at full it is -5 degrees, i know this is wrong but how do i adjust it.. twisting the links from the servos to the swash plate?
and that's all done at half throttle?
