He is running the DX8, so same menu as you and I. As stated, go into the swashplate menu and adjust the Pitch (ONLY) to -60. Then, put your Tx at mid stick, set 0º pitch on the blades, then check full stick, and low stick. If you have more low than full, then your swash plate is too low and you need to lengthen your servo to swash links. If you have more full stick pitch than low stick, then your swash plate is too high and you need to adjust the links shorter.
After each change, you will nee to adjust the blade grip links to get back to 0º of pitch at mid stick, then check it all over again. This part takes time.
