Crud, I just put on the fuse thinking i was close. The blades do turn withouth the motor turning but very stiff. Will disassemble as instructed and find the problem. Thanks Paul, Tony!
Just remembered reading something about stiff gears when i first started this build so went back to Century to check and found this:
Q. Why are the gears so tight on my helicopter?
P. When I try to turn my main gear, all the gears seem to be very tight, making it difficult to turn them by hand. Alternately, when I have changed my main gear, it again is difficult to turn the main gear in the helcopter.
A. Century uses a proven, dual gear reduction mechanism to deliver power from the engine to the main rotor head. When the helicopter is new, it is normal for the drive gears to be tight. Just wait for 4-6 tanks of fuel while the engine is wearing in to have the gears become silky smooth. Unlike most of the other designs in the market, where there are only two gears, the clutch bell and the main gear, our helicopter has four. The key benefit with this type of design is to reduce the loading on the individual teeth of each gear as there are more teeth engaged at all times.
Be carefull if you have changed the clutch bell, and installed a new lining by bonding it into the clutch bell with JB Weld. If the amount of adhesive is excessive the gap between the clutch and the bell will be too small. Use only a small amount and spread evenly on the liner.
