rchelipilot
Great.!! The suspense has been hard to handle......
one thing to try take the elevator stick pull back on it then let it go on its own while you are in the air. If your cyclic is unstable that will usually cause it to oscillate
nano-techs I see people complain about them but its usually from people who by a 35C battery that should have purchased a 65C and then complain when it puffs. I have only rarely had a problem with nano-techs. The one problem I did have was a low cell. So one thing to do which I always forget to do is measure each individual cell BEFORE you charge them. If one is low don't think that charging it will fix it send it back. That cell may get "fixed" but will always be droopy.
If it's reading that high of number its more likely the person didnt set the poles and gear ratio up correctly in the tx menu
HELI TACH! .....
Not flying now ..... due to snapping off a ball joint (Threadlocked) during replacement of my servo arms ... I was not happy with the short 14.5mm ones ... as the angle under the swash plate was very acute.
So I went for these:
I did not buy it for an FBL controller.... I bought it for a bail out feature sepcifically.
I was on the understanding that it would work and when it shockingly did not, I was annoyed. I was not even doing anything but a stable hover.
Anyway. Ikon are going to implement some of my ideas.Got a few emails yesterday thanking me for Ideas I have posted on the forums. Their head developer has contacted me also and will be implimenting a few of them as soon as possible, so the new firmware upgrade will be partly my conceptual ideas.
see here
