Hmmm....Noted! Thanks for finding that. Anybody looking for a NIB SC-BUG??? LOL!
I'm starting to think people don't understand what a BEC is
(Battery Elimination Circuit) it was intended to run off the main packs and eliminate the need for a separate RX pack. Makes no sense to have a BEC and a separate RX battery IMO.
I'll run a BEC on helis up to 6S-8S but on 12S setup I just use a separate 2S RX battery it makes more sense and can handle the load demands of the HV servos.
I chose the BEC route on my G630 in an effort to save grams, I don't have another battery to care for or charge/forget to charge, and I can have a constant current running to the servos. I may not notice the voltage drop as a Rx battery drains, especially flying sport, but in my mind I want a constant current to the controls. I chose the WR Hercules BEC because it has a high input voltage rating of 60V and can handle 15 amps continuous and 20 amps peak. I thought that this would handle anything I could throw at it with a low risk of failure and I would have the headroom to push it if I wanted to. Also, the WR has a power bus and allows for direct connection of the servos to the BEC. In my mind, this provides for optimal power to the servos with minimal servo connections. The FBL is powered by a direct connection to the BEC as well. In addition, I don't have to run HV through the FBL.
I have HV servos (rated at 6.0-8.2V) and though I would run them in the middle at 7.4V and the WR BEC allows for easy switching. I also have the option of running 5.2V, 6.0V, or 8.2V through easy dip switches located on the unit. My only concern is mounting the BEC underneath the frame but it needs to be in a well ventilated area. In a belly crash that will be the second thing to hit the dirt after the landing gear breaks.
