Right, Lee. I knew that, wasn't thinking.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
More on this later...
So... the big day.
Brought it down the LHS and they gave it a once over, ran through the beastx config, etc. They guy helping me was pretty impressed that I got it built and the beastx configured as well as I did for a first time build. I chalk it up to good instructions by Blade and all the build vids Tony and the rest of you put up on here, and the help you all offered as I was going through.
So we spun it up and did some hovering in the parking lot. First he did, at my request, just in case it did something squirrely he'd have a better chance of saving it than I. That went well so I took it up for 5-10 seconds or so. Long enough to know I had to dial in a bit more rate limiting and expo. It wasn't bad, but just a bit touchy for my tastes. Probably could have gone with a higher expo only, but wanted to cover my bases.
No vid of this. It was a total of 20 seconds of air time between the two of us, and I felt odd asking the guy to video it.
So I got it home and, since I had a partially drained battery, figured why not.
[video=youtube_share;JWhmSBRo__8]http://youtu.be/JWhmSBRo__8[/video]
Of course, my camera's sd card ran out of space.
Suffice it to say, the flight ended well at the 4 minute mark (my starting point to see how long the battery will last). I'm impressed with the power of it. Even light pitch bumps (as seen in the vid) produced prodigious lift compared to any three of my other helis (120SR, nano cpx, and a large but old quad). Tail hold and control was amazing compared to the nano and 120sr too. I think I see a slight side to side wobble in the tail when I put it into slow forward flight. Going to pay more attention next flight and maybe bump the gain down a touch.
So Flight 1 and 1.5 were a total of about 4m20s. Battery took 1900mah of power on recharge and voltage was only down to 23.8v or so. So for this kind of non-spirited flight I can go 8 min on a battery, will set timer to 7min to be safe.
Off to inspect it now. Make sure nothing came loose. Then take her up again. I have the day off and it is nice out!
![049 :hdbng: :hdbng:](/images/smilies/049.gif)
