I got my sats and gov sensor, but sadly my last order did not show
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Hopefully I'll have it Monday.
After all the feedback on the exhaust gasket I thought I'd take it out and make a custom one. Now, the reason the stock gasket was not "good" was because it covered up the exhaust outlet on the motor. But when I removed the muffler and looked at the stock gasket again, I noticed that even though it's smaller than the motor outlet - it's a perfect fit over the muffler inlet! So I'm keeping it on there.
At least now I got a sat to hook up to the AR8000 so I can center up my servos
Instructions want 18mm spacing for the ball on the servo arm, but I can have 17 or 19 on the Align arms - so I went with 17.
Per the instructions I mounted the ball on the inside of the arm, but that just didn't look right.
Also, two out of four bolt securing the servos had to be cut down due to them being too long.
Got out the Dremel and shortened four bolts.
To get the servo geometry right I had to get creative with the balls. (LOL)
Hmmm...
Servo arm stopping on the servo casing - not good.
Cracked a link. These Gaui links are brittle and of poor quality - I'll swap them out for Align links and balls later on I think.
More tinkering with spacers and positioning to get the geometry right.
Nope.
Tried out some Align balls I had lying around. But they were too small for the Gaui links - and got sloppy.
With Align ball.
Moved the ball on the outside. This is what I ended up with - geometry good and straight.
I got myself a larger BEC. This one will do 8A
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Should do the job I think.
Comes with led indication on battery capacity. Fancy.
Started with the link for the rudder. The manual states the rod is 255mm, and that the rod WITH links is 245.5mm. LOL what?
Rudder servo mounting.
So Gaui obviously suck at getting the lengths right in the instructions - but they also suck at cutting the rod to the correct length.
That rod is barely long enough to reach the rudder horn.
Had to figure out the geometry here as well.
The rod was just long enough to get the links threaded on good, so it's gonna work - and it's gonna be safe.
Installing the push glow.
Button.
Connecting to glow plug.
Mounting the BEC. I couldn't find a better spot, but it works and the canopy fits.
Throttle servo.
Throttle servo and BEC switch mounted.
Throttle servo rod too long. I'm glad I own a Dremel...
The ball mounting for the throttle arm stopped against the motor.
Grinded down the head of the bolt that hit the motor.
After a bit of swapping and fiddling I got it to work with proper geometry.
Oh yeah, on full throttle the link binds against the arm. To fix it I'll just grind it down 1 mm or so.
Boom.
Never seen this design before - I like it
Tail.
Never seen this design before either. Nuts instead of bolts for the tail feathering shaft.
You have two positions for the tail hub. All the way out, or a bit inwards.
I choose the "a bit inwards" position, as I experienced some binding when the slider reached the end of the shaft.
What? These bolt look a bit long.
When I tighten the above mentioned bolt I get some serious binding. I'll try to figure out this tomorrow.
All the balls, links, rods and servo related stuff sucks on this model - not impressed. The overall quality looks good though, but there will definitely be modifications to this model.
