I was wondering. You all are referencing the gov mode. What exhactly is this? Everything I ever read on governors was regarding nitro models. Why would you need a gov on an electric? What are you all doing with gov on electrics! Even the directions for my 3 G unit references nitros! Please explane in Laymans terms that I will understand. Why are you using a gov on an electric heli?
On a bigger model electric or nitro, now a days with the motors and batteries that are being run, running a governor is almost inevitable on the electrics.
In a nitro you are trying to save the engine from over revving..
In electrics, with extreme power and no limit on headspeed ( exaggerating but you know, nitro is confined to 2200 2250 on this size , while electrics can do much higher) , you look and extreme amount of radial forces that work on the spindle shaft, blade grips and blades... If you go above a certain head speed like say descending, and your motor keeps revving when under no load, you are running a risk of burning that electric motor, and not just that, you run a risk of as soon as load your head, your head basically just tearing itself apart. And yes it happens.. Cause the instantaneous stress and G that we are putting on all those metal and carbon fibre parts are much more that they can handle ...
In my old nitro bird, I had to run a governor not to save my motor but my head as it was plastic and small diameter spindle and not made for 3D, I really couldn't risk it going too fast on it, or would have tore itself apart.
Another big reason is gyros .. ESP flybarless... They prefer a constant headspeed than every changing with environment, and that is not just from your curves but also your motor over or under revving at a particular point.
I had the same questions as you.. And i found all this out. Hope this helps
Now please don't think I am saying that Marius's bird can't handle high G maneuvers and high head speeds, it can, but he would rather run a governor and keep it safe and stable than see his bird dissipate in mid air.
lol I am sure we all will
hahahahha
Fly safe!!
have fun!
