Your input has been taken into consideration. Thanks
But I have been doing some reading on the topic, and turns out the 140° swash is technically speaking the
perfect set-up when so called "interactions" are to be eliminated completely. This has to do with the swash servos not moving exactly the same length; the elevator servo actually has a different "stroke/throw" than the aileron and pitch servo. The difference is very little and only noticeable for very experienced pilots. This difference is also compensated for in the Tx and/or the Rx/FBL to some degree on 120° systems.
And in spite of having the option to choose this fabulous set-up, I'm going with the 120°. Why, you may ask? Well, turns out most of the RC-world is still using 120° and therefore most FBL systems are designed around 120° set-ups. Not that a 140° swash would be a problem on a high end FBL, but I'm going with "budget" BeastX, and don't want to take the chance. Also there's the fact that I'm used to flying 120° on my 450, and I would like the "feel" of both my JR and Align to be as similar as possible.
On some parts of the instructions I have the choice between 120° or 140°. From this point on I will be building per the 120° set-up.
_______
Tonight I assembled the swash arms.
Bearings installed.
Balls.
The A-arm for the elevator came like this in the package. The plastic "shaft" on top there had to be broken off.
Bearings.
A-arm assembly completed. I did not tighten the linkage rod, as JR operates with the same inn/out markings as Align does. The small JR brand on the link is supposed to be out, but if I've tightened the rod now the brand is pulled into the top of the plastic "tube" and I won't know which way is which when I come to mount this thing.
Main gear assembly.
This step was very easy. Only four bolts to be mounted. Anti rotation bearing comes pre-greased.
I've been waiting on this baby for some days now, and finally she arrived
Turnigy SK3 Helidrive Competition series. 560 KV. 4100W.
I have been concerned that I would have to machine or drill my motor mount, as the Hobbyking website stated the motor has 25mm bolt spacing and utilize M4 bolts. My JR however has the two possibilities; 2x M3 with 25mm spacing, or 2x M4 with 30mm spacing.
Hobbyking's tech spec. Notice the
Screw Mounting Spacing.
The JR's motor mount.
Well, either I'm a moron at understanding specs, or Hobbyking have not provided the corrrect specs on their website. Because all the holes match up PERFECTLY
