Slobberdog
Derek what motor you running cos the Align 450mx is 3400 kv, not sure how much diff that will make though
Just checked... 95-90-85-90-95 throttle curve on idle up... 13 pitch pos & neg.. My cyclic is at 9 degrees... Now I use the AR7200... Ur on the 3GX right.. I don't know if there are any differences between the 2 gyros w my numbers... I'm pleased with them tho... Hope that helps.
U could look at my flight in the video section and compare the sound.... U said urs was screaming... That was in a 45c pk as well
I got ~4050RPM for your high headspeed. 3600 * (3 * 4.2) * .9 * (12/121) Not sure why my number and the Mr. Mel number is so different. And that's only considering motor efficiency. You'll have mechanical losses in the drivetrain too, losses due to torque, etc.
It is high, though. 2800-3600 seems to be the range people fly at in my short research effort.
11T pinion would get you down to 3700ish RPM.
