pitch: mid stick should be 0 ... but as far as your pitch curve in "Stunt" position on screen or "F.Mode on 1" is 0-25-5-75-100.. and you pitches are equal both ways.. then you are good. i mean there might be some tracking required... that may fix something. if not.. you are good to go..
Dont fly in f.mode on position 1 yet. Yes keep it at 0 .
The engine tune : 1.5 turns is default. 1 turn is way too lean. esp for the stock muffler you got on there. that'll need more fuel intake. I am on curtis younglood MP5 muffler and i run 1 turn and 5-6 of clicks out. Mp5 consume less fuel.. But tune is different for every engine, and temperature and many more factors. start off at 1.5 turns out on high and where is your low speed? default as per manual? (in line with the carb opening) ?? if you have ny doubt post a pic
start out with 1.5 turns. engine will be spitting out fuel, and will be healthy but low power. then tune slowly two to three clicks at a time.
Please donot be afraid of sounding dumb around here. Again Dumb question is the one you didnt asl.. and that caused injury to the heli or far worse.. you..
so ask away!!
apart from that, try to see of you can get those traning skids, and try to hover it, will have less power and will go through fuel fas, but you will be able to track the blades, and then we here can help you tune.
(as far as we can) .. best way is to get someone locally and have them help you do it.. but We here can definitely walk you through the steps in theory
