Hi
Well I'm going to give this plane ago as an A3 size instead of a A4. This partly due to the printer being set to A3 as default when I printed.
After joining all the pages together the size of the plane is roughly 800mm long with a wing span of 1050mm.
This is roughly an increase in size of about 300mm from the A4 version.
I'm going to use both 5mm and 10mm forecore for the build. The 10mm will be used for the vertical part of the body and 5mm for the horizontal. The wings will be 5mm as per the original plans. The wings will be done as two parts, partly because the foamcore I ordered is 550 x 800.
Well that's it for now, justing on materials
Cheers
Cheers
