Island Breeze
Senior Rc-Help Member
Wait wait wait NO
ikon travel adjust for the Tx made you adjust the travel adjustment to match 100 percent right? You might have ended up with 110 or 120 up and down?
Don't change that. Never touch travel adjust in the Tx after the ikon Tx setup page. It'll screw a whole lot up
Fly safe!!have fun!
I left TX adjustment at 100% and only adjusted in ikon..never had to touch the TX except to move throttle stick up and down when adjusting from ikon. if correct my next step is to adjust the ramp up/down and the rest, is there a baseline for that...or do I have to do a trial run in the field?
on throttle I ended up with around 900 sum on low and 1200 sum on high..I forget, but its around there. thanks for the help..i do have more settings left to do and will throw my questions out there. thanks fellas
and Tony...E-Razor! LMAO NO! it was an eraze
