Successful maiden fellas! once my friend uploads the vid i will post it. This thing is freaking insane, at 1/4 stick this badboy want's to go. GABA the IKON Gov gave me probs so i had to field program the ESC which is just fine. I will check back on the issues on IKON gov, at work at the moment lol..oh and another thing.. nervs and shakin at the same time is not a good combo fellas and to top it off i am learning to pinch the sticks. WHEW!
On smack talk they go over this. Burt applies so much pressure his thumbs bleed lol.Bert kammerer thumbs his helis. I don't agree you have any more or less control either way... It's the way your hand is so::: anatomically and ergonomically what's better for you. Don't force a style on yourself . I tried pinching ... Doesn't work for me. I lose track of my sticks much easily. I rather got bigger gimbals for my radio so I have more surface area where my thumb sits and that has helped me a lot. Much more comfortable and feels very locked in without the fear of slipping
Fly safe!! have fun!
ya! that whole pinching thing made my hand numb there for a while. LOL I had to re-adjust my sticks.
So Gaba back to my IKON gov. I had everything set up accordingly but it seemed to stay on one head speed and not change at all even when switched to IU. this was my steps:
1. set all end points to 100% on ikon.
2. advance mode on gov setup put low/high throttle to mid for esc setup endpoints. also inputted HS at time
3. ESC set to heli and external gov. unplug batt and then plug in esc to ikon
4. power up TX with throttle to high and then power up heli.
5. then in ikon gov set, I moved slider up until I hear confirmation from esc. once confirmed I move throttle stick to low and then move low throttle slider in ikon until I hear confirmation from esc again.
6. remove ikon usb unplug heli and replug to confirm initialize.
esc and ikon initialize at that point. but when tested on field there was no change on HS.
So the ikon governor brought the head up to speed to say normal mode but never switched to id1 and id2 speed ... Is that what happened?
The steps you posted and did are perfect . If your esc initializes every time you plug it in, that's perfect.
Now what were your throttle curves set to..?
The 30 60 100 percent they ask to set on throttle curve for the three rpm's :: needs to be set using the ikon software... Try to see that on the basic screen , the throttle slider that moves with the stick or with throttle curve, corresponds to 30 or 60 or 90 .. Doesn't matter what transmitter says
How have you connected your hobbywing sensor to the ikon... And to the motor... Mind posting pics?
I want to remind you of this :: I have done this myself----
Pin out on hobbywing sensor that comes from factory could be different than what ikon demands :
http://img.tapatalk.com/d/13/06/04/besaja2u.jpg
Pin out on that jst -zh plug goes ::SIGNAL ---NEGATIVE --POSITIVE
Once you have it right, spin the motor with your hands and you'll see actual rpm values... They shouldn't be fluctuations say 10-500-600-8000 back... .. But actual realistic values
Was "use governor" checked for the bank you were using in the ikon?
check the port config bro.. the picI posted was for the Ikon's Governor port : pin out. So make sure its hooked the right way. I had to change the wires config as the hobbywing sensor pin out did not match the ikon's gov port.
All at once is fine. If there was an issue , the esc won't initialize. Just make sure it is right at the point at which it initializes not too lower
Let me know what you see on the sensor
