The plastic links on the tail should have a brass sleeve in them. This sleeve should NOT be tight in the plastic. If the sleeve is not as long as the plastic, then you need to sand the plastic down. The bolt will tighten to the sleeve, adn the sleeve will act as a bushing.
If you are referring to the metal linkage where the plastic link slides in, then just use a very little amount of thread locker, and snug it down, but again, the brass sleeve should keep it from binding.
If neither of these are what you are talking about, then a picture or video may help explain it a bit better.
