haha, Have to stay in the truck. Heading to California. Compton to be exact. So I may not need to jump from the truck, or maybe I will hahaha.
Go to letter "L" and make sure that the servos and swash plate respond to your stick command. This is were you Rev. servos if you have too. Hope this helps.Hey ! Boss
I'm little confusing on setup K of the microbeast... When I put the throttle up the pitch gauge show negative (blue light)and when I put in low position (stick down) show positive in the pitch gauge .. Should it be backwards?
Stick up the swash should go up and vice versa. The trailing edge of the blades when moving the stick up should go down. Just have to be clear on this. I'm not sure what pitch gauge you are using so there is no way to know how you have it mounted.
Good luck with your test flight tomorrow, have fun and," "I just figured it out on the Blade 300cfx ! I just reverted the pitch on the Tx ! Everyday I learned something new!!! Thanks guys !! Tomorrow I gonna try my 450l ...outside for sure!!!
Ok so what is the % tail gain you have set in the BeastX software?
Well .. When I plug it the blue light stay on! And all the letter is off ..When you plug in the BeatsX
What LED colour do you have and what letter is lit up.
You need to look at page 63 in the manual to learn about gyro gain.
