Well, I broke down and had to do it. I'm getting tired of having to carry extra batteries with me and the new IPV3 uses dual 18650 batteries from everything that I'm reading. However, they are wired in series and not parallel, but still, that's going to lower the load on teh batteries. we will see. I have purchased into the preorder in hopes that they ship out soon. And $118 for a 150w regulated mod (yeah, my CC is screaming at me right now) is a steal. I firmly believe this is a DNA killer right here. Hell, the 50w IPV2 is a DNA killer, and that one can be upgraded to 100w.
I do see what you are saying about the lowest wattage setting. I do wish it went a little lower. 5w would be the lowest I would go though. But, even with my Kayfun, I'm finding myself needing 15w or more. As stated, I'm running it, with a 1.4 coil on my MVP at 11w and it's just not enough. But also, the draw is WAY too tight for me. Which is the reason I went ahead and purchased the Magma.
I watched Rip Trippers video on the Magma and in there he stated that "if it was not sent to him, he would NOT have purchased it". And this is because he was comparing it to the kayfun with the air hole right under the coil. And he would have been wrong and highly suggests the Magma to anyone. So, I have it on the way (yeah, it's already shipped. Smoking fast!) and we will give it a shot. Going to wind a dual coil 28g twisted at, I"m thinking, 8 wraps each. Should get me up around about a .7 build. Right now, .35 is my sweet spot on my mods. But if the flavor is like everyone is saying it is, I can up my ohms by double, and get the same flavor out of it with a cooler vape and longer battery life.
Just mixed up some 60/40 PG/VG juice to try in the kayfun. I'm running 20% on the flavoring with no nic right now (forgot to put it in and filled the bottle up lol). We will see how it does. Need to rebuild the kayfun, or re wick it anyway, so it will be a true test.
I am itching to get the IPV3 though. It will be my first REAL box mod. No, I don't consider the mvp as a "mod". Just like I don't consider the iTaste VV a mod. The only difference between the two is battery size and you can use the mvp as a power bank. The other thing that I'm looking forward to on the IPV3 is the RDA will sit lower as there is NOT eGo threading on it. If you want to run an eGo style tank, which I don't see why anyone would on a 150w device, you can just use an adapter. It does have a spring loaded 510 which I'm a little worried about, but we will see.
