Okay, I have been hitting this thing for a while now and have formed an opinion with it sitting on top of my Pegasus.
The RDA looks amazing. Even with that ring being 23mm and the body 22mm, the black color hides it quite well. The etching on it is great, nice and deep and should last.
I did switch down to some 50/50 juice and the flavor did come up, but still not where I thought it would be. But as I stated above, the flavor is on par with the Tobh with both of them wide open. I have tried the other two holes and as it should, the flavor went up slightly, but so did the temp of the vape. Again, I"m running a .54 dual coil setup, so it's warm to begin with.
Dripping this RDA is a MAJOR PAIN IN THE ASS!!! If you drip through the drip tip, you will ALWAYS get juice flowing out of the air hole(s). I have to, on 100%VG, drip 10 drops, then do a dry suck on the RDA then drip 5, dry suck, then drip 5 more. This fills up the wells in the RDA. But, if you try to do 20 straight drops, you will get juice running all down your mod and your hand.
This leaking is not so bad with the 50/50 juice. It seems to fall down a lot easier into the well. But after about 20 drops of 50/50 (with a needle tip) you still need to do the dry suck to keep it from coming out of the holes.
I have found that taking the top off is the easiest way to fill this RDA although it is a pain since you have to either make sure your air adjustment doesn't move or you have to line up your holes again.
Speaking of air holes, I'm running this thing wide open with dual 3mm holes and the draw is still pretty tight for me. It's just slightly tighter than the Tobh wide open. But, this is a flavor RDA so this part is tolerable.
I have noticed that the drip tip hole is a little larger, only slightly, than most RDA's out there. If you are running a white silicone O-Ring, then it's loose. If you are running a rubber O-Ring, then it's pretty tight. The raised area for the drip tip, I don't like. I have multiple tips that are larger than the raised area, and I have some that are smaller. I have not found a single one yet that is the same size. This is an OCD thing but I don't like that.
I want to get my IPV3 and wind a 2.4 ohm coil, dual, to get more surface area and see how that vapes. I am also about to chance my coil to a twisted 28ga dual coil to see if that helps any. And finally, I"m going to try some flat wire in here. There is another coil that I want to try that incorporates flat wire, 28ga and SS mesh which is supposed to have insane flavor. But, it's a lot of work and usually doesn't turn out right. So I may not do this one. But, I need to find my coil before I can make a determination on this RDA. I'm still hitting it, which is more than I can say for the stilare. lol. The stilare needs dual O-Rings to hold the top cap to the base.
back to testing... The wife just went to pick up my Paragon mod from the PO. So it's going to be sitting on "IT'S" mod soon.
