You'll see the astrik I think in the upper left side of the screen for the default settings on the ESC. I generally run my heli's on the recommended settings, except for gov store. You should probably at first set it to no gov, then do throttle end points using linear curve. After that go back program gov store, close out the program, set throttle curve to 50% flat, all the way across. Turn radio back on switch on Throttle hold, put stick to center position, then flick off TH. Let it sit there and run for about 20 seconds. Hit throttle hold, shut down everything, then go to a flat 65 or 70 throttle curve flick off TH and see how she does.
