Hi guys! Update time...
Well it wasn't raining but it was a bit windy. Ah heck, I'm going for a test flight today, I ain't wait'n.
After I reset the head again; she again flies good.. The blades are tracking perfect too, with just a half turn on one of the blade linkages after spool up . For the technically curious, I was flying with the blades set at about a 11.3 average pitch. The swash was set at 75+ ……
Silver mark blade, pitch + 11.2 negative 11.3 and the center is +.2/3..
Blue mark blade, pitch + 11.5 negative 11.3 center is +.5/7..
I'm in the hangar again tonight and still playing with the numbers. When I dial up the swash setting to the max point, (94+),, where the washout block is just about to touch the heads base and the swash is barely touching the frame; once again the blades pitches move off the cherry setting. She still flies good though, not bad. HA!
Ok guys, time for the question of the day..
Now that I know I want to set my max pitch at about 13/13.5 degrees. That would be great for me. Shouldn't I just reset the blades with them in the 94+ swash setting position?? You know what I mean? Balance them out with the higher swash setting; right? Then if I go a bit lower, the over all settings should change as much; right??
I can't wait to see your guys response on this. Were almost there; yeah babee!
Rster...
