The 460MX comes in two types, the 1800kV version (for 6S power) and the 3200kV version (for 3S power)... it's absolutely critical that you know what motor you have. If you power the 3200kV motor with a 6S battery the ESC and motor are likely to go up in smoke.
You would be far FAR better just sticking to the battery and motor type that the heli was designed for. Many beginners think 'bigger must be better' for batteries but that's not true because bigger is also heavier and weight reduces heli performance and doesnt actually extend flight time by much because the heli uses more power to lift the extra weight. If you did go the 6S route then the mAh capacity must go down, so the batteries for a 450 are generally either 3S 2200mAh or 6S 1250mAh (plus or minus 100mAh either way). But for your heli the 3S is recommended because the 6S is unlikely to fit. Strapping the battery underneath might 'work' but it would be a 'bodge job', look awful and make the battery prone to damage.
I'm afraid the downside of electric power is relatively short flight times.. this is just the way it is. The solution though is simple, get a few batteries.
