So I managed to maiden the 700X on Sunday.. A mixed report, first the good news:
Maiden went perfectly. I started with a governed throttle % at 70, 75 and 80. For sports and mild 3D 80% seemed about right (I'm guessing 2000RPM). She flew real nice, felt quite light in the air. For the second flight I bumped up the tail gain (I'd started with it deliberately low) and re set my throttle % to 75, 80 and 85. I also turned down startup power in the ESC to '2' (default is 3) to address a slight kick on spoolup. The changes worked well and she was flying perfectly.
Now the not so good
On spool-up for the third flight (after changing nothing at all) she became unstable, wobbling on all axis. I managed to catch it and powered down. I power cycled the heli and everything seemed to be working fine so i put it down to maybe the FBL not initiating properly. She spooled normally and was flying perfectly until about 30 seconds into the flight doing a slowish straight and level pass right in front of me control was suddenly lost and she started pirouetting wildly. I hit throttle hold but couldn't do anything to prevent a crash. Fortunately it wasn't going too fast and I hit TH pretty quick but 700 size helis don't like being thrown into the ground tail first! The damage runs to: tail boom, torque tube, tail blades, tail shaft plus bearings, tail skid, front tail drive gear, front landing gear snapped, bent landing gear skid pipe, very slight chipped tooth on auto gear, cracked canopy, slight chips on one main blade.
The most frustrating thing is that I cant figure out the cause of the crash. It certainly wasn't 'dumb thumbs' as she was just flying straight and level when all hell broke loose. After recovering the heli the servos were not responding normally to tx input, they seemed to be going in random directions as if the FBL wasn't set up. When I stripped it I didn't find any mechanical problems, no loose screws or detached links or cables and all servos appear fine. The FBL data log was unfortunately inconclusive because I spent so much time testing the heli afterward that I must of overwritten whatever the data relating to the crash. There were multiple missed signals in the log but that may have related to after the crash.
My best guess is that it's a FBL fault. The Vbar that went in it was bought second hand and this is the first time I've used it, it came from what should have been a reliable source but you never can be 100% sure. Strangely though it seems to be working fine again now. Fortunately I have another spare FBL and the sat receivers I ordered for the heli will be here soon (the ones installed were borrowed).. so I can change out both FBL and receivers. Getting the spares to make the repairs is not so easy because the dealers here don't have much in stock for the 700X so it will likely be grounded for a while
Some photos:
I have videos of the first two flights and of the problematic spoolup but frustratingly the camera battery crapped out seconds before the crash so I only have the take off on the last flight. i'll post the vids one I have chance to upload them.
